the 88 4.0 efi auto does not want to stay started the first time i start it.. I'm thinking it may be a fault code or something similar. its a renix system. is there anyway to read the codes??
it starts then stalls right away and the battery light comes on , then goes off and it starts fine after that
Turn the key to on twice before cranking. If that works the fuel pump relay is probably going bad. I swapped mine for the AC one (it's there, but my truck had no AC. Go figure?)
k ill try that.. i have AC, but it does not work.. so maybe ill do that ..
Can i put anon AC serp belt on and remove the AC compressor and all the AC junk (no reason to carry all that extra weight around)
There is an idler pulley and a bracket to hold said pulley on non-ac models, If you place the bracket and pulley in place of the compressor, then yes.
