dave92cherokee Posted August 25, 2010 Share Posted August 25, 2010 Working on building up my cheromanche and trying to figure out possible vehicles to get the new rear seats from. Was thinkging about trying to find a 60/40 split buckets like the newer S10's have. Would have room for 3 when needed and when not needed would add extra cup holder. I'm sure I'm not the first to do this so if you know of some seats that fit and look good let me know what vehicles you found them in. Link to comment Share on other sites More sharing options...
mnkyboy Posted August 26, 2010 Share Posted August 26, 2010 I took these from a 97 Dakota Link to comment Share on other sites More sharing options...
LarryH88bt Posted August 26, 2010 Share Posted August 26, 2010 ^^^^^^^^ :thumbsup: That's nice. Will have to remember that. I've got old XJ seats right now that are absolute garbage. Did they just bolt in? Link to comment Share on other sites More sharing options...
mnkyboy Posted August 27, 2010 Share Posted August 27, 2010 No They didnt bolt in. i had to make all the mounts Link to comment Share on other sites More sharing options...
anthony Posted September 3, 2010 Share Posted September 3, 2010 i put the 60/40 s10 seats in one of my old mjs .. just cut off the old base below the slider, built a frame out of square tube, welded on tabs and bolted it in .. a little bit of a learning curve one the passenger side because it went over the tunnel, the driver's side went in like a glove .. one tip, use a level across the seat from door to door or you'll have to take them out and do it over because it will look goofy from outside the back window durango power buckets like above are going in my present daily driver .. doing the same thing as the s10 seats Link to comment Share on other sites More sharing options...
