How hard were they to replace?
Anybody know about an o-ring between the PS pump and resevoir?
They aren't hard. The old ones were actually rusted on so bad that I cut the lines off and used the impact to get the fittings out. Hence getting new lines. The only reason I was having problems is that I moved my radiator so the lower hose makes it a REALLY tight fit.
Dunno about pulling apart the pump. I doubt it's bad at all.
Just be sure before driving to start it up after replacing the line(s) and crank the wheels side to side until the air bubbles are gone from the system. Then top up the reservoir.
