beaterheep Posted August 10, 2010 Share Posted August 10, 2010 picked up an 88 manche, 4.0 5spd longbed, looking to do soa with an 8.25 axle(probably just use the d35 for now) wanted to know if the 8.25 would bolt in or if i need to move the spring perches? thanks!! Link to comment Share on other sites More sharing options...
Eagle Posted August 10, 2010 Share Posted August 10, 2010 You have to move the perches. The center-to-center distance for the XJ is different from the MJ. Link to comment Share on other sites More sharing options...
beaterheep Posted August 10, 2010 Author Share Posted August 10, 2010 that sucks, was hoping itd be a simple bolt in. oh well, new perches are 15 bucks shipped from summit racing, now i just need to find an 8.25 for cheap... Link to comment Share on other sites More sharing options...
Eagle Posted August 11, 2010 Share Posted August 11, 2010 You can re-use the original perches. The welds are only along the outside, and easy to grind off. Link to comment Share on other sites More sharing options...
beaterheep Posted August 11, 2010 Author Share Posted August 11, 2010 true. does anyone know offhand just how much of a different there is perch to perch for a comanche compared to a cherokee? Link to comment Share on other sites More sharing options...
Pete M Posted August 11, 2010 Share Posted August 11, 2010 enough to warrant moving the perches. if you force the leafs to match the XJ axle, you'll destroy the bushings in the leafs. It's been done. Link to comment Share on other sites More sharing options...
