90 Comanche
4.0 L
4WD
D30 front 8.25 rear 3.07's for now
Spring over rear and 4.5" Lift coils in the front
I will be starting the body work here shortly. Flat black will be going on.
But first to get some tow points aka new bumpers
before
Image Not Found
Image Not Found
after the spring over and new 8.25 installed
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Good to see another Canadian on here, an Albertan at that.
Was reading it earlier on CJA.
Nice truck, looks good :clapping:
One question, when you swapped in the 8.25 did you move the spring perches?
Yes I had to cut off the old perches and weld on new ones for spring over
are you still using stock control arms and stock tracbar
Yes but parts are on the way to ugrade steering. And I will be getting control arms made for it shortly
