My 4x4 conversion is coming together and I have sourced an NV3550 tranny for a fair price. I have an existing NP231 that was behind a 1988 4.0 Auto that I was thinking of using, but would rather have the NP241. I've read that the NP231's behind a 4.0 were always 23 spline input shafts.. is that correct?
As for the NP241, since they were behind Automatics, is the input shaft a different length?
Long story boiled down to a simple question... If I get a 2001 NV3550 and a late 90's NP241, will they match up?
Thanks for everyones help and patience.
What did the NV3550 come out of? If its out of a wrangler they are clocked higher and add to that the larger case of the NP241 and i don't think it would even come close to clearing the floor.
231s and 242s before 1990 were all 21 spline, 91+ all 23 spline.
there ARE different shaft lengths though i do not know what they are.
not quite true.
All t-cases behind the autos were 21 spline until the HO model year in 91. The AX-15 however has always had a 23 spline output, and Jeep started putting those in mid 89.
The NV3550 is coming out of a 2000 XJ... Also, I meant to say NP242, not NP241... sorry...
