1987Comanche Posted July 18, 2010 Share Posted July 18, 2010 This isn't strictly MJ related as it's for a 2000 XJ but it is 4L so I figured it's close enough. My friend's 2000 has had mysterious coolant loss since he purchased it and I figured it was the 0331 cyl head casting. He had a few other issues so he brought it by and, in the process of digging around the engine bay I discovered that the thing has the wrong water pump gasket! You can clearly see an unused bolt hole in the gasket at the 2 o'clock position and you can also see that the top bolt has no gasket above the bolt. I suppose it's also possible the gasket was not clocked correctly with respect to the water pump but, from what I can see, it looks like the wrong gasket. Was Toledo really this bad?? :nuts: Link to comment Share on other sites More sharing options...
jimoshel Posted July 18, 2010 Share Posted July 18, 2010 I would suspect a PO before I'd blame Toledo. Link to comment Share on other sites More sharing options...
aemsee Posted July 18, 2010 Share Posted July 18, 2010 The WJ block used a different bolt configuration than the previous blocks, using 5 bolts instead of 4. Chrysler recut the H2O pump gaskets to fit either application, with the new gaskets actually having 6 bolts holes in them. Link to comment Share on other sites More sharing options...
ratrapp Posted July 18, 2010 Share Posted July 18, 2010 did he have the gasket flipped over?if so the top holes won't line up but the bottoms will. Link to comment Share on other sites More sharing options...
1987Comanche Posted July 18, 2010 Author Share Posted July 18, 2010 The WJ block used a different bolt configuration than the previous blocks, using 5 bolts instead of 4. Chrysler recut the H2O pump gaskets to fit either application, with the new gaskets actually having 6 bolts holes in them. This makes sense. I would imagine they recut it so it would harder to mess up during install. A guy at work has an '01 so perhaps I can look under his hood and see if it's the same. Link to comment Share on other sites More sharing options...
