what is the bolt size for the bolt underneath this bracket?
its the rear of the frame right behind where the shackles are
lol hijacked the pic :P
I'd advise you to start spraying your bolts down now with PB or something similar if you're gonna try to remove them in the future. They are notorious for snapping off inside the nutstrip inside the framerail.......
Jeff
They are 10mm. I think Red was referring to the size socket that fits the head. Red ... that's not what designates the size of the bolt. Bolt size is the major diameter of the shank.
