STERLING STINGER Posted July 15, 2010 Share Posted July 15, 2010 no responses first time i asked, so i figured id try again i just got my 2.5" lift on my 92. the end links are to short. i have no way of welding them longer at this time. i need new ones. where or what can i get them from? thanks paul Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted July 15, 2010 Share Posted July 15, 2010 no responses first time i asked, so i figured id try again i just got my 2.5" lift on my 92. the end links are to short. i have no way of welding them longer at this time. i need new ones. where or what can i get them from? thanks paul Make accurate measurements, and ship them up to me, I'll weld them up and ship them back to you... CW Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 15, 2010 Author Share Posted July 15, 2010 thanks for the offer cw, but i think theres an easier and faster option out there. isnt there another end link out there thats two inches longer than the 92 that i can go to autozone and just buy? thanks again for the offer. Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 15, 2010 Share Posted July 15, 2010 They changed the length around 1992. The old end links are 7-1/4" long; the newer ones are 8-1/4" long, p/n S-18162 at AZ. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 15, 2010 Author Share Posted July 15, 2010 horn, i have those on now..if they what az calls for on their computer for a 92 comanche.they arent long enough....what about off another truck? f150 i think i read somewhere are longer Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 16, 2010 Author Share Posted July 16, 2010 or someone throw me a link for some adjustables? theres like a thousand diffrent kind online and idk which ones to get :dunno: Link to comment Share on other sites More sharing options...
Justin_k Posted July 16, 2010 Share Posted July 16, 2010 ZJ ones. What i'm using on a 4.5'' lift and fit about perfect Link to comment Share on other sites More sharing options...
kyleag89 Posted July 16, 2010 Share Posted July 16, 2010 Advance auto parts sells aftermarket ones in the so called performance section of the store. They have two different lengths and I'm pretty sure the longer one should work for you. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted July 16, 2010 Author Share Posted July 16, 2010 i just went to advanced auto with a 92 oem end link and told them to bring me several diffrent oned fron diffrent jeeps. i ended up finding one 2" longer with a knuckle on top. i forget what its from, but the part # is K3197 i installed it...i had to use the bushing from the oem for the top tho. seems to work great...i still need an additional 1/2 inch...but they should do well see in a couple hundred miles... :popcorn: here's some pics Link to comment Share on other sites More sharing options...
mkbruin Posted July 16, 2010 Share Posted July 16, 2010 I heard once that the rear links from a mid-90's F350 are a match. If you need additional length, look for one of these at a u-pull-it. Link to comment Share on other sites More sharing options...
kastein Posted July 26, 2010 Share Posted July 26, 2010 i just went to advanced auto with a 92 oem end link and told them to bring me several diffrent oned fron diffrent jeeps.i ended up finding one 2" longer with a knuckle on top. i forget what its from, but the part # is K3197 i installed it...i had to use the bushing from the oem for the top tho. seems to work great...i still need an additional 1/2 inch...but they should do well see in a couple hundred miles... :popcorn: here's some pics Parts app database says it's for a TJ and perhaps some years/models of JK. I'm gonna pick a set of these up and hope for the best... Link to comment Share on other sites More sharing options...
