Northup Posted July 8, 2010 Share Posted July 8, 2010 I was wondering what my original paint color on my comanche is called. I would like to repaint it myself as close to match as possible. Rust is being fixed its a really dark marroon. Was wondering if someone knew the name 1j7fj36sxml520483 Link to comment Share on other sites More sharing options...
Automan2164 Posted July 8, 2010 Share Posted July 8, 2010 I think your truck is too old to tell by the VIN. You are better off using the body code tag on the firewall on the drivers side. It will have a paint code. I know a few members on here have the code breakdown. Rob L. :cheers: Link to comment Share on other sites More sharing options...
mfpdm Posted July 8, 2010 Share Posted July 8, 2010 http://www.automotivetouchup.com/paint-codes/jeep.htm It should be on the label plate on the firewall drivers side. :cheers: Link to comment Share on other sites More sharing options...
dasbulliwagen Posted July 9, 2010 Share Posted July 9, 2010 Some of these codes have been recycled by Chrysler, so not all of them are accurate...such as the code for the Kicker SRT sound system. But anyways, this is the info directly from Chrysler. In-Service Date: October 10, 1990 In-Service Odometer: 216 Miles Build Date: September 11, 1990 Hour: 12 Selling Dealer: 66797 - POULIN CORPORATION Sales Type: 1 - DIRECT RETAIL City: ROCHESTER State/Province: NH Recall Number 747 Description DISC BRAKE ROTORS Launch Date March 5, 1998 Repair Date April 28, 1998 Last known owner is listed, as is original owner (though I can't give out that info) Color 1: PM9-DESCRIPTION NOT AVAILABLE Color 2: QM9-DESCRIPTION NOT AVAILABLE Standard Equipment Code Description APAS Monotone Paint BAPS 75 Amp Alternator BCXS Nickel Metal Hydride Battery BGAS Power Front Disc/Rear Drum Brakes CUMS Mini Floor Console DHNS Command-Trac Part Time 4WD System DJHS Dana M30/181MM Front Axle DMMS 3.07 Rear Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass HCDS Heater w/Instrument Pnl Ventilation JCAS 85 MPH Primary Speedometer K3ES DESCRIPTION NOT AVAILABLE LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MMCS Upper Door Frame Moldings MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF5S DESCRIPTION NOT AVAILABLE QM9S DESCRIPTION NOT AVAILABLE SBAS Power Rack and Pinion Steering SCES 2-Spoke Soft Feel Steering Wheel SFAS Standard Duty Shock Absorbers SGAS Rear Shock Absorbers TBMS Tire Carrier Winch XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 131S Zone 31-Boston Optional Equipment Code Description *C1 DESCRIPTION NOT AVAILABLE -H9 DESCRIPTION NOT AVAILABLE ADLA Skid Plate Group ALN Spring Special White Appearance Grp ARLA Kicker/SRT Livin' Loud Audio System CBAP Straight Back Bench Seat CKAP Carpets - Floor and Cargo Area DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission ERH 4.0L I6 Power Tech Engine GFDA Rear Sliding Window GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZA Manual Remote Mirrors JAYA Instrument Cluster w/Tach JGBP Digital Clock JHAA Var Intermittent Windshield Wipers JJAP Cigar Lighter KKSP DESCRIPTION NOT AVAILABLE KWSP DESCRIPTION NOT AVAILABLE K2BP DESCRIPTION NOT AVAILABLE K27P STRIPE/BADGE/MOLDING MBJP Black Front Bumper MDAP Front License Plate Bracket MHAP Black Windshield Moldings MMKP Body Color Drip Trough Molding PM9 DESCRIPTION NOT AVAILABLE RAAC All Radio Equipped Vehicles RAFA AM/FM Cassette Radio RCDP 4 Speakers TBBA Full Size Spare Tire TMWA P215/75R15 OWL All Terrain Tires TZHP Michelin Brand Tires WJDP 15X7.0 Styled Steel Wheels WLYC All Steel Wheels YEA No Optional Sales Codes YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z66P Left Front Group XV Z85P Right Front Spring Group XIV 3V3A Customer Preferred Discount Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 9, 2010 Share Posted July 9, 2010 Try this site http://www.tcpglobal.com/autocolorlibrary/ it shows paint chips (for '86-'88 select American Motors), the paint code is probably on the driver's side firewall tag (this is from a '90) . Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted July 9, 2010 Share Posted July 9, 2010 Hey nice link to the touch up paint for paint codes. I've been trying to figure out what the color name for my Buick was, and now I know (even though I should have guessed)! -Comanche - Beige -LeSabre - Dark Cherry Metallic -Escape - Vermillion Red Neat link. Link to comment Share on other sites More sharing options...
Northup Posted July 9, 2010 Author Share Posted July 9, 2010 Thanks so much for the links and help!! The color name is Black Cherry. Once I finish the power steering pump I will be moving back to the body work and will post some photos. Link to comment Share on other sites More sharing options...
