link16 Posted July 1, 2010 Share Posted July 1, 2010 Lets start of with: I have a 1988 Comanche with a 4.0L Renix mated to a 5spd transmission. Everything is stock in the engine bay. I am having a slow over heating issue. I over filled the expansion tank and it boiled over, I replaced the cap with one that was on a newer '90 cherokee and it did not stop the issue. I can drive for about 20+ miles before the needle passes the 210 mark, but it doesn't stop until just before the red. My antifreeze is bright green, and is fresh. I did jack up the truck and pulled out the sensor in the back of the head, and got a mouth full of hot antifreeze. I assume I did something wrong there. When I turn off the truck I can hear a sizzle from the expansion tank cap. I am going to swap the tank with the new cap and see if it is just a mating issue. How much do I fill the expansion tank up? What could I be doing wrong, and could someone illustrate a little clearer how to bleed the cooling system? Link to comment Share on other sites More sharing options...
Automan2164 Posted July 1, 2010 Share Posted July 1, 2010 Are you sure the bottle isn't cracked? The system needs pressure to keep the boiling temperature up. Afterall, the boiling point of water is 212 degrees. By keeping the system under pressure, it raises the boiling point. I guess what I am getting at, is if you can hear hissing around the bottle, there is pressure getting out. It will not perform like it should until the pressure is sustained. I might take a closer look at the bottle. Rob L. :cheers: Link to comment Share on other sites More sharing options...
Harper Posted July 1, 2010 Share Posted July 1, 2010 There's a little post directly below the filler neck, as you look inside the pressure bottle. On all the bottles I've seen, the bottom half of the post is round, and a semi-circular portion sicks up above that. Fill to the top of the round part of the post. Any more than that, and it's likely to overflow. Bleeding the system...raise the rear of the truck a ways, engine cold, remove the temp sensor at the left rear of the cylinder head, fill until coolant runs out the hole, replace the sensor, check coolant level in the bottle as described. If you're seeing coolant around the cap or elsewhere on the pressure bottle after running at normal temps, assume it's got small cracks and won't hold pressure. At the temps our trucks run, if it won't hold pressure, it will boil and overheat. As automan pointed out, the bottle is always suspect. Link to comment Share on other sites More sharing options...
link16 Posted July 1, 2010 Author Share Posted July 1, 2010 I will apply this stuff to my efforts tomorrow. Thank you guys. I will report my findings and my solution tomorrow. -Alex Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 1, 2010 Share Posted July 1, 2010 Another good reason to convert from the troublesome closed cooling system to an open system. By the time summer's over there will be 1,009,453 posts similar to this. :peek: :cheers: Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 1, 2010 Share Posted July 1, 2010 ...By the time summer's over there will be 1,009,453 posts similar to this. :peek: Like this? http://www.comancheclub.com/forums/viewtopic.php?f=2&t=23276&hilit=coolant Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 1, 2010 Share Posted July 1, 2010 Happy bleedin' mate. :rotfl2: Link to comment Share on other sites More sharing options...
link16 Posted July 1, 2010 Author Share Posted July 1, 2010 ...By the time summer's over there will be 1,009,453 posts similar to this. :peek: Like this? http://www.comancheclub.com/forums/viewtopic.php?f=2&t=23276&hilit=coolant Finding a clearly depicted bleed process is not easily found in a search. I did searches and I got choppy and conflicting information. Thank you for your help guys. Link to comment Share on other sites More sharing options...
Eagle Posted July 1, 2010 Share Posted July 1, 2010 Finding a clearly depicted bleed process is not easily found in a search. I did searches and I got choppy and conflicting information. "Bleeding" is for brakes. "Burping" is for the cooling system. Link to comment Share on other sites More sharing options...
link16 Posted July 1, 2010 Author Share Posted July 1, 2010 Finding a clearly depicted bleed process is not easily found in a search. I did searches and I got choppy and conflicting information. "Bleeding" is for brakes. "Burping" is for the cooling system. What do we do to clutches? :) Sorry, if we're arguing semantics, I can't resist. Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 1, 2010 Share Posted July 1, 2010 Alex, Don't mind us crotchety old me. :cheers: I would replace the bottle and/or cap, seems like your system is burped. This thread may have some useful info if you haven't come across it already. http://www.comancheclub.com/forums/viewtopic.php?f=2&t=24052&hilit=thermostat Link to comment Share on other sites More sharing options...
