1990 Jeep Comanche Base
As it sits now, pic taken last weekend:
4.0L, AX-15, NP231, Dana 30/C 8.25 29sp, 4.10's, LWB
Build Date: 8/89
Still on the road as a weekend warrior/wheeler, no longer a Daily Driver
When I bought it, it was in fair condition with MT springs and a D35, my build sheet states it has this because of the upcountry package. I also have the towing package, and the offroad package. The truck also came with a topper. The floorboards have NO RUST, I give the rubber floor credit for that. This MJ has a bench seat
As it sits now, I have swapped the D35 and disco 30 out with 99 XJ axles and 4.10's. I have 6.5" of lift with 4.5'' RE springs and a spring over rear. Rear aussie locker is installed and JCR offroad sliders and prerunner front bumper. WJ booster swap was done over the winter
  • 8 years later...
*X2 TRIM STYLE X2 - VINYL BENCH
-SA Charcoal
174 Zone 74-Denver
1AA U.S. Dealer Retail
ADH Heavy Duty Electrical Group
ADL Skid Plate Group
ALA SE Decor Group
APA Monotone Paint
AWE Night Eagle Package
BA1 100 AMP ALTERNATOR
BCY 475 AMP BATTERY
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMM 3.07 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GNA Rear View Day/Night Mirror
GRV Left Manual Mirror
GUA Open
HCD Do Not Use - See HCA
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
K3Z STRIPE/BADGE/MOLDING/COLOR
KWX DK QUARTZ - BADGE - "INTREPID" - DECKLID
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAF High Altitude Emissions
NBK EVAP Control System
NF5 Fuel Tank - 23 Gallon
NMC Heavy Duty Engine Cooling
PW7 Bright White Clear Coat
QW7 Bright White Clear Coat
RA8 Delete Radio
SBA Power Rack and Pinion Steering
SCB Perforated Steering Whl w/Red Stitch
SFD Front Extra HD Shock Absorbers
SGD Rear Extra HD Shock Absorbers
TAA All Tires
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TRN P225/75R15 OWL Wrangler AT Tires
WJD 15X7.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
XEA Tow Hooks
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z66 Left Front Group XV
Z85 Right Front Spring Group XIV
Body Model JL62
Build DAte 10/12/89
  • 1 year later...
