88pioneer Posted June 23, 2010 Share Posted June 23, 2010 finally got my 8.8 today, just need to wire wheel it and do some brake work. My question was, do i need to shorten my drive shaft to fit the 8.8? Also, how do i adapt the pinion to accept the MJ's drive shaft? Thanks in advance :cheers: Link to comment Share on other sites More sharing options...
Darren Posted June 23, 2010 Share Posted June 23, 2010 Here you go: http://www.mountainoffroad.com/_e/Ford_ ... _YJ_TJ.htm Link to comment Share on other sites More sharing options...
kastein Posted June 23, 2010 Share Posted June 23, 2010 Cheapest I found the flange was alljeep.com's store, it's Spicer 2-2-1379. http://www.alljeep.com/oscommerce/produ ... _id=167208 Not sure about driveshaft length. Link to comment Share on other sites More sharing options...
camjeep3 Posted June 24, 2010 Share Posted June 24, 2010 i don't think you will need to shorten the shaft... i has soa and mine needs to be lengthened if anything.... the shaft was for a d35 if that helps Link to comment Share on other sites More sharing options...
88pioneer Posted June 24, 2010 Author Share Posted June 24, 2010 thanks for the links, and i have the same setup as you camjeep, besides the auto, so that should all work. Thanks for the help :cheers: Link to comment Share on other sites More sharing options...
