Door Lock Cylinders
I was getting ready to order these lock cylinders for my '90 model MJ from Quadratec, but I saw that it only listed 1984 Cherokees and some CJs.
http://www.quadratec.com/products/55014_101.htm
Then I found a set at Team Cherokee that lists the correct years, but are more expensive (2nd one down).
http://www.teamcherokee.com/Locks_and_Keys/index.html
Are these the same parts? Or are the '84 XJ locks different than what I have in my Comanche? I'd like to save a couple bucks by getting them cheaper, plus I have something else I need to order from Quadratec, so I'd save on shipping.
I really don't know if they are the same or not, but in my thinking, the only difference MAY be that the electrical connector for it is year specific and won't plug right up.... thats my guess.... and I mean GUESS. Its probably the same part with an earlier style connector, so you might be able to cut and swap connectors and make it work.
my problem with the locks from the store is you don't get a glove box door lock to match :dunno:
Who locks the glove box? I haven't locked the glove box in any vehicle for at least 35 years, probably closer to 45.
