jeeping31 Posted June 21, 2010 Share Posted June 21, 2010 Year: 1991 Make: Jeep Model: Pioneer Engine: New crate 4.0 HO /Killed the stock 4.0 Trans: Auto think Aw4 Transfer-case: Used NP231/ Killed the stock np231 Front axle: Used XJ Dana 30 with Vac gear 456s / Killed the stock Dana 30 Rear axle: Cry 8.25 with 456s /Killed the stock Dana 35 Other Stuff: Comanche OME skid plates NO AC options Exterior color: RED Interior color: Grey Buckets seats Rusty Motor Mounts Rusty Over-the-Knuckle Steering and Heavy Duty Tie Rod Rusty Drop Pittman Arm 3" Spring-over leaf springs Rubicon Express 5.5 lift kit Rusty 1.75 Poly Spacer Rusty .75 Poly Spacer New large Gas tank Back sliding window G-3 core radiator Bed mount Roll-Bar Now I took off my short-arms and coils and sold them now looking for long arms and coils! I got a buy of 8 inch rusty coils for $100 but I need to make up my mind about 3 link or four link can you help me make up my mind? Next thing is can someone tell me how to take off the shifter to get the carpet up? Link to comment Share on other sites More sharing options...
91MJdude Posted June 21, 2010 Share Posted June 21, 2010 just pull it up hard, hit it up with the palm of your hand. Link to comment Share on other sites More sharing options...
89eliminator Posted June 21, 2010 Share Posted June 21, 2010 yeah, your gonna have to pull up hard (most likely). don't be surprised if you bust your hand on something. i would go 4-link for the long arms. its more stable and with 8" coils, your gonna need the stability. are you gonna make the long arms? Link to comment Share on other sites More sharing options...
jeeping31 Posted June 21, 2010 Author Share Posted June 21, 2010 Thank you for the info stay tune this going to be fun! And I'm thinking of going rusty off-road long arms, Me and him crawl under my MJ at the telico NAXJ run. He took my time and its not forgotten and I deal with him before. Link to comment Share on other sites More sharing options...
jeeping31 Posted June 21, 2010 Author Share Posted June 21, 2010 Okay got it off But now I come back to what Pete said **Quote--Pull up your carpet! EVERY MJ owner should do it asap. I don't care what climate you live in or how little rust is on the outside of your truck, there must be a dozen ways for moisture to get under the carpet and once it's there, it's only a matter of time before the floor rots out from under you. Quote--** Link to comment Share on other sites More sharing options...
Pete M Posted June 21, 2010 Share Posted June 21, 2010 bummer man. :( but at least you know how bad it is and can fix it up before it gets even worse. :D tech questions should really go in the tech forum so more people will see it and also so that it'll be in the database for future searches. :thumbsup: Link to comment Share on other sites More sharing options...
