echdaviem Posted June 19, 2010 Posted June 19, 2010 where can i buy molded carpet for reasonable price?
Automan2164 Posted June 19, 2010 Posted June 19, 2010 Ebay is a decent place, as is JCwhitney... but be aware, that none are direct fit, or the same quality... What's wrong with the carpet you have now? They do pretty well in a commercial washer... Rob L.
dasbulliwagen Posted June 19, 2010 Posted June 19, 2010 Or pull it out, and take it to the car wash and hit the whole thing with the pressure washer after spraying it down with a color safe degreaser. Then if you have any wierd color spots you can touch it up with a spray dye in a similar color.... a guy i know just did this to his Ranger V8 project, and it turned out nice!
1987Comanche Posted June 20, 2010 Posted June 20, 2010 Junkyard. I pulled XJ carpet for my truck and it's a reasonably close fit. I had to cut it down but for $8 I could live with that.
echdaviem Posted June 22, 2010 Author Posted June 22, 2010 i used to have the vinyl flooring and it was fine but i took it out to check the floor and it kinda got all ruined when i took it out. and it was all gross and nasty wet on the padding. so there is no one that sells molded carpet that actually fits? i understand you have to trim to fit but what about over the hump? does it fit well there?
Boilermaker Posted June 22, 2010 Posted June 22, 2010 i used to have the vinyl flooring and it was fine but i took it out to check the floor and it kinda got all ruined when i took it out. and it was all gross and nasty wet on the padding. so there is no one that sells molded carpet that actually fits? i understand you have to trim to fit but what about over the hump? does it fit well there? Search for "ACC" and "carpet". You'll find a couple of threads where their molded carpets are discussed.
wannabeMJ Posted June 23, 2010 Posted June 23, 2010 Ive used one from my cherokee donor and the only thing I had to cut is the lenght and the rest is 95% direct fit
-600JeepMJ Posted June 24, 2010 Posted June 24, 2010 Carpet? I pulled mine out and rinolined the floor and left it like that.
echdaviem Posted June 24, 2010 Author Posted June 24, 2010 i was thinking about doing that. you can't feel the heat coming off the floor? i'm in florida so i need to insulate as much as possible. the heat in the summer is rediculous
shark Posted August 3, 2010 Posted August 3, 2010 i was thinking about doing that. you can't feel the heat coming off the floor? i'm in florida so i need to insulate as much as possible. the heat in the summer is rediculous yeah, i feel you man. my daily driver XJ is herculined and i have no a/c. it's brutal. i live in tampa. the MJ I'm building now will have plenty of insulation and a/c. i don't care how much it costs. wasnt so bad this winter. now that my girl is driving my other XJ i have to drive my trail rig every day. 1/2 hour each way. brutal.
