smithe1811 Posted June 14, 2010 Share Posted June 14, 2010 Year, Make, Model. 1988 Comanche Pioneer SWB Image Not Found Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase 4.0, BA10/5, NP231, D30, D35, 3:07 gears Build date: May 1988 Current Location: Northeast PA Status: Daily Driver/under construction Notes: Anything that makes this comanche different from the rest. Skid plates, plows, lights, bumpers, weird factory options... Would also be a good place to note the exterior color, and the interior color and combination, IE, Bench or buckets, Vinyl or cloth, column shift or floor shift. Red exterior, gray interior, factory gas tank and transfer case skid plates, factory roll bar, factory tow hooks factory interior lights package, factory cargo light, factory bucket seats(replaced with XJ wing backs), XJ center console, self installed sun roof, 4 inch lift, 1 inch throttle body spacer, K&N cone intake with intake tube, ford 302 19lb fuel injectors, 97+ XJ side mirrors, replaced idiot lights gauge cluster with tach cluster, upgraded to H4 headlights Current owner: Well, you know. Put down who has it, the yard its in, or anything of that sort. Smithe1811 (Erik) Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 24, 2019 Share Posted May 24, 2019 Build date: Correct Link to comment Share on other sites More sharing options...
fiatslug87 Posted June 24, 2020 Share Posted June 24, 2020 Build sheet please. Link to comment Share on other sites More sharing options...
JMO413 Posted June 25, 2020 Share Posted June 25, 2020 Whole Vin doesn't work. If I try the last 8 it comes up as an XJ Link to comment Share on other sites More sharing options...
