Gjeep Posted June 10, 2010 Share Posted June 10, 2010 I am looking to confirm something on your trucks. I'm installing complete 1991 HO 4.0L, AX-15 5-speed wiring in my '89 Comanche. For those of you with the 1991 4.0L, 5-speed combination can you take a peek at the PCM plug (driver inner fender). You don't need to unplug anything. There's a cap over the PCM plug that conseals the wiring. Unfasten the 2 clips that loosen that cap. If you are standing in front of your truck at the header panel/ front bumper it would be the top row of 10 wires closest to you. You won't have to dig at all to see there. I believe the order should be (starting closest to the PCM plug mounting bolt) : NO WIRE (pin slot is capped), MEDIUM BLUE, BROWN (?), ORANGE, PURPLE/WHITE, BLACK/WHITE, BLACK/BLUE, RED, TAN/BLACK, GREEN/RED I have a 1991 FSM and I looked at the starting diagram and believe it is incorrect a bit for the manual transmission, so I am looking to confirm off an actual vehicle. Thanks. Link to comment Share on other sites More sharing options...
alex_and_sean Posted June 10, 2010 Share Posted June 10, 2010 I have a 90 configured this way but can't see what you are looking for. Is the 90 set up differently or am I being dense? Based on the day I have had I am expecting the latter. If the 90 and 91 should be similar tell me again what I am looking for and I will look again. Link to comment Share on other sites More sharing options...
Eagle Posted June 10, 2010 Share Posted June 10, 2010 The 1990 was the last year for the Renix system. 1991 was the first year for the Chrysler HO system. They are completely different. Link to comment Share on other sites More sharing options...
Geonovast Posted June 10, 2010 Share Posted June 10, 2010 Link to comment Share on other sites More sharing options...
Gjeep Posted June 10, 2010 Author Share Posted June 10, 2010 Thanks for posting. I'd like to get another couple people to chime in to see if their 91 has the brown wire between the blue wire and orange wire. For some reason my 91 MJ 4.0L 5-speed harness did not come with this wire over to the PCM -- and it does not look modified. My wire just goes straight from the starter relay to the starter. It wouldn't be an issue except I am not using the PCM the wiring harness was originally matched with. I live in CA, so I will be plugging the harness into a CA-emissions PCM versus the Federal PCM it came with. I've got all my wiring out and am looking to get it right the first time. Thanks Link to comment Share on other sites More sharing options...
Geonovast Posted June 10, 2010 Share Posted June 10, 2010 I'd look at the 2.5's just for the hell of it, but the damn hood won't open. Link to comment Share on other sites More sharing options...
DJM/78 Posted June 10, 2010 Share Posted June 10, 2010 I feel so bad man , I completely forgot to upload the pics you asked me for , I'll get one of mine to ya tomorrow . :fool: Link to comment Share on other sites More sharing options...
Gjeep Posted June 11, 2010 Author Share Posted June 11, 2010 BTT Link to comment Share on other sites More sharing options...
DJM/78 Posted June 11, 2010 Share Posted June 11, 2010 Here you go : Hope that helps . Link to comment Share on other sites More sharing options...
Gjeep Posted June 11, 2010 Author Share Posted June 11, 2010 Thanks Dave - Your MJ is wired like mine at the PCM - that being without the brown starter wire to the starter relay. I know you live in CO, but out of curiousity, do you have a CA emissions MJ? It would say California on the emissions label located on the firewall. Correy - I'm guessing based your location you've got a FEDERAL emissions vehicle? Thanks again all. Link to comment Share on other sites More sharing options...
DJM/78 Posted June 11, 2010 Share Posted June 11, 2010 Nope CO truck , CO emissions its been here all its life ! :dunno: Link to comment Share on other sites More sharing options...
Geonovast Posted June 11, 2010 Share Posted June 11, 2010 Haven't looked, but from what I can tell, it's been a WI truck most of its life, and basically, WI doesn't give a rat's @$$ about emissions. Link to comment Share on other sites More sharing options...
