1J7FJ26L1LL229260
ComancheKid45
Year, Make, Model.
1990 Jeep Comanche sport
Image, if available
Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase
4.0L inline 6/AW4/NP231/D30/D35/LWB
Build date: (its on the driverside door sticker, in the form of month and year)
3/90
Current Location: Region will do, state, and area of state.
Shippensburg, Pennsylavnia (South Central PA)
Status: Is it still on the road, is it in the junkyard? Project awaiting work?
Parts Truck due to frame detereration and failed transmission for 1JTMP6313JT012484 or any other MJ owner possibly in need
Notes: Anything that makes this comanche different from the rest. Skid plates, plows, lights, bumpers, weird factory options... Would also be a good place to note the exterior color, and the interior color and combination, IE, Bench or buckets, Vinyl or cloth, column shift or floor shift.
Unknown on the orgional color name, interior is gray with cloth bench seat and headrests. Column shift. not many other notable features.
Current owner: Well, you know. Put down who has it, the yard its in, or anything of that sort.
BJ Naugle (myself) in my yard for now.
  • 8 years later...
*X1 TRIM STYLE X1 - CLOTH BENCH
-SA Charcoal
143 Zone 43-Pittsburgh
1AA U.S. Dealer Retail
5KK First American Title Insurance CO.
ALA SE Decor Group
ALK Italia Package
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Nickel Metal Hydride Battery
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHN Command-Trac Part Time 4WD System
DHT Elec,Shift-on-the-Fly,P/Time T/Case
DJH 230MM Front Axle
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GNA Rear View Day/Night Mirror
GRV Left Manual Mirror
GUA Open
HCD Do Not Use - See HCA
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JJA Cigar Lighter
K3Z STRIPE/BADGE/MOLDING/COLOR
KWW T: BRILLIANT WHITE - NAMEPLATES - W
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF5 Fuel Tank - 23 Gallon
PB8 MIDNIGHT BLUE MET CC PRI PNT - HB8
QB8 MIDNIGHT BLUE MET CC SEC PNT - HB8
RAA All Radio Equipped Vehicles
RAB AM/FM Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCB Perforated Steering Whl w/Red Stitch
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z66 Left Front Group XV
Z84 Right Front Spring Group XIII
Body Model JL62
Build Date 3/14/90
  • 1 year later...
