STERLING STINGER Posted June 8, 2010 Share Posted June 8, 2010 here's the info 88 mj Turn key...it turns until it stops...turn hard then loud click and cit turns all the way everything will turn on, fan i direct wired, fuel pump,etc but when i turn the key, nothing I go mess with the terminals, which are a good contact to battery, and itll start. or even sometimes ill wiggle the shifter...or turn on the lights and itll start???? Any ideas? Its happening alot more often now. Oh yeah, when i turn the truck off, thwres a 5 sec delay before it actually shuts off...idk...stumped Link to comment Share on other sites More sharing options...
AmJay Posted June 8, 2010 Share Posted June 8, 2010 Is this the MJ you changed the lock cylinder on? It sounds like the ignition switch needs adjustment. It's held on by 2 bolts and you can loosen those bolts and slide the switch up or down on the column. Tighten the screws and test, repeat until it works right. Mac... Link to comment Share on other sites More sharing options...
1987Comanche Posted June 8, 2010 Share Posted June 8, 2010 My '87 4 banger did crazy stuff like that when the starter was going out. Wiggling the cables, etc would sometimes help but it was random and drove me nuts until I figured it out. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 8, 2010 Author Share Posted June 8, 2010 Is this the MJ you changed the lock cylinder on? It sounds like the ignition switch needs adjustment. It's held on by 2 bolts and you can loosen those bolts and slide the switch up or down on the column. Tighten the screws and test, repeat until it works right. Mac... yes i did juat change the tumbler...Is there a thread on this? Thanks Paul Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 26, 2010 Author Share Posted June 26, 2010 still can't figure this one out guys. heeeeeeeellllllp :bowdown: Link to comment Share on other sites More sharing options...
maddzz1 Posted June 26, 2010 Share Posted June 26, 2010 Have you checked all the little wires over near the battery that go to the power dist center? One may be loose or corroded and not getting a good connection. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 27, 2010 Author Share Posted June 27, 2010 power distributipn center? the clump of wires by the coil? Link to comment Share on other sites More sharing options...
maddzz1 Posted June 28, 2010 Share Posted June 28, 2010 Yeah, in between the battery and where the relays are under the hood. There are a bunch of little wires and fusible links. If it also makes a click when you turn the key forward it could be the starter like said above. Turning the key more times may just be bumping it enough to turn the starter and start the truck. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 28, 2010 Author Share Posted June 28, 2010 it starts and runs Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 28, 2010 Author Share Posted June 28, 2010 no signals, radio, heater though Link to comment Share on other sites More sharing options...
maddzz1 Posted June 28, 2010 Share Posted June 28, 2010 Did you check the fuses since this happened? There are actually 2 fuses that control the radio. but one of them actually controls some othert stuff too. It says acc/int or something like that and one just says radio. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted June 28, 2010 Share Posted June 28, 2010 DBL check all battery cables. If nothing found there, search NSS or Neutral Safety Switch cleaning... CW Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 28, 2010 Author Share Posted June 28, 2010 it ws the ignition switch..found 2 burnt switches...now how do i adjust so y key turns back to the lock position Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 29, 2010 Author Share Posted June 29, 2010 noone? Link to comment Share on other sites More sharing options...
