STERLING STINGER Posted June 1, 2010 Share Posted June 1, 2010 oil pressure gague Heater fan Wiper I was just coming home and these things all just shut off on me....in the rain...all at once. I have no clue????? just replaced tumbler and headlight switch. Tons of problems all at once#*%#-#+$-% Link to comment Share on other sites More sharing options...
64 Cheyenne Posted June 1, 2010 Share Posted June 1, 2010 Yep, they all related in the sense that they are all electrical, needing a complete circuit positive to neg to work. I'd start with checking grounds. Battery, especially engine to body. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 1, 2010 Author Share Posted June 1, 2010 Cool I'm actually learning. :) Other than the battery and the drivers tail light, doea anyone know where any others are? I'm really leaning toward it being something with the ignition, or it being in park all the way, or something incredibly hard.....but grounds first Link to comment Share on other sites More sharing options...
Pete M Posted June 2, 2010 Share Posted June 2, 2010 I had to run a new ground to the dash in my 88. everything worked better afterwords. :D Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 2, 2010 Author Share Posted June 2, 2010 Where is it by the dash Pete? do u know where all the grounds arw located? Link to comment Share on other sites More sharing options...
64 Cheyenne Posted June 2, 2010 Share Posted June 2, 2010 Sometimes the ground strap from the block to firewall can be the culprit, especially if it is mucked up. Jeep ran the chassis ground through the block then to the firewall. Bad idea. Some guys run a separate chassis ground from the battery to the fender, circumventing the block to chassis ground. Be aware you still need that ground though (engine). Link to comment Share on other sites More sharing options...
Pete M Posted June 2, 2010 Share Posted June 2, 2010 I'm not sure where the factory one is. I ran a new wire from the battery to the metal part of the dash above the drives feet. If I remember right, I was having trouble right after installing an aftermarket radio (which was asking for lots more juice). Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 2, 2010 Author Share Posted June 2, 2010 Ok thanks ill look Link to comment Share on other sites More sharing options...
64 Cheyenne Posted June 2, 2010 Share Posted June 2, 2010 Another thing to check, turn heater fan on, check for voltage at the heater motor. If you have voltage, then probably a ground issue, no voltage, then power supply issue. You can unplug the heater motor at the bulkhead (under the pressure bottle if Renix) to check for voltage. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 2, 2010 Author Share Posted June 2, 2010 K ill look thanks Link to comment Share on other sites More sharing options...
beaterjeep Posted June 2, 2010 Share Posted June 2, 2010 Do your horn and radio still work? If not, I had similar issue on my XJ (no horn, wipers, radio, heat/fan control) and it turned out to be a fried ignition switch (among a LOT of unneeded wires from PO :headpop: ). Link to comment Share on other sites More sharing options...
STERLING STINGER Posted June 2, 2010 Author Share Posted June 2, 2010 Do your horn and radio still work? If not, I had similar issue on my XJ (no horn, wipers, radio, heat/fan control) and it turned out to be a fried ignition switch (among a LOT of unneeded wires from PO :headpop: ). Isnt that the white box the tumbler shaft goes into? Link to comment Share on other sites More sharing options...
beaterjeep Posted June 2, 2010 Share Posted June 2, 2010 No, the ignition switch is down lower on the column. Towards the firewall, pretty much on top of the shaft. Mine had a blue connector going into it, with I think it was 5-6 wires coming off of it. HTH. Link to comment Share on other sites More sharing options...
