xj axles on an mj
there is a difference in the spring perch widths. it CAN be bolted straight to your leaves but its definately NOT the kosher way to do it. though it has been done.
XJ leaves are to short for the MJ
best way to do it is to chop the perches off and re-weld new ones wherever you want them... SOA SUA wherever.
EDIT: front axle is a direct bolt in.
To clarify,
The front of a ZJ, XJ, TJ, & MJ are interchangeable was far as the control arms and related bracketry. So any of these are a bolt in for ya. There are some other differences, like rotors, hubs and steering linkage, but they will bolt right up no problem!!
The rear is different and NOT a direct bolt in. First off, XJ's are SOA while MJ's are SUA.
As Oizarod mentioned, the leafs themselves are a different legnth so that won't work at all.
You need a set new of spring perches. The width's are different. XJ leafs are mounted outbound of the "frame", while MJ's are directly UNDER it.
Just grind/torch off the factory perches and re-weld on the new ones in the correct locations. :chillin:
CW
I'm at 7.5 or more in the rear with SOA in my short bed and only had to lengthen my DS alittle but no SYE and i don't see any use for it. Had 0 issues with it pulling out or cramming in to far. With a Long Box there may be a difference though.
Cole
tbummer your not closer man i would almost make the drive if it were a bit closer, do u ever drive in this area. sorry i will start using that button
Is the "dell" in "dellstopjeep" for Delaware? If so.... no. Not often.
Yeah, we don't generally care about the search button. Pete kinda setup the site as the best one ever, and we all get along. It's weird.
i was just giving Eric (delstop) crap. I told him about that truck he just bought.
but hey! feerocknok there is a group of three of us 'manche owners here in vancouver, wa you should come to one of the naxja events with us. last one i was the only mj there.
I'd love to! Once the Manche's running (oh God, I hope soon. It's SOOOO close) I'll be going to Portland for the heck of it. Maybe a trip a lil bit up for some wheelin should be in the mix too!
