daltonmcgill7 Posted May 27, 2010 Posted May 27, 2010 my comanche won't start it has fuel pressure has spark do you think it could be bad gas? its been siting without the neck on so I'm thinking it could have gotten water in it also my gas gauge says its full whn i no its not it probly only has a gallon iin it.what could that be? :dunno:
Red 1989 MJ Posted May 27, 2010 Posted May 27, 2010 We have probalbly a faulty CPS. Check the DIY section for testing. :typing:
daltonmcgill7 Posted May 27, 2010 Author Posted May 27, 2010 just figured out that oim now getting 0 fuel pressure but i hear my fuel pump working could it be a cloged fuel filter
88pioneer Posted May 27, 2010 Posted May 27, 2010 ballast resistor, white ceramic piece on the inside of the driver side fender, controls electrical signals to the fuel pump
daltonmcgill7 Posted May 28, 2010 Author Posted May 28, 2010 ballast resistor, white ceramic piece on the inside of the driver side fender, controls electrical signals to the fuel pumpbut wouldnt that make the fuel pump not work at all i hear it running but get no fuel :huh???:
Oizarod115 Posted May 28, 2010 Posted May 28, 2010 We have probalbly a faulty CPS. Check the DIY section for testing. :typing: he says he has spark so CPS is probly good. no fuel pressure could either mean the truck is OUT OF GAS... (silly mistake, don't let a failed gauge let you down) probably not a blocked fuel filter if this just started happening out of the blue but you can replace it cheap and know thats good. check and be sure the pump has a full 12v and then pull the line before the filter and see how much (if any) it pumps.
88pioneer Posted May 28, 2010 Posted May 28, 2010 not necessarily, my resistor went bad, but my fuel pump still kicked on. It doesn't keep the pump from getting power, it tells when to send the fuel. Try by- passing the resistor with a piece of wire to see if thats your problem
daltonmcgill7 Posted May 28, 2010 Author Posted May 28, 2010 well i finally got fuel pressure but still no start I'm thinking its got bad gas is there a way to drain the tank without taking it completly out or do u think i should pour some seafoam in it
daltonmcgill7 Posted May 28, 2010 Author Posted May 28, 2010 We have probalbly a faulty CPS. Check the DIY section for testing. :typing: he says he has spark so CPS is probly good. no fuel pressure could either mean the truck is OUT OF GAS... (silly mistake, don't let a failed gauge let you down) probably not a blocked fuel filter if this just started happening out of the blue but you can replace it cheap and know thats good. check and be sure the pump has a full 12v and then pull the line before the filter and see how much (if any) it pumps. thanks ill try this
Oizarod115 Posted May 28, 2010 Posted May 28, 2010 if the pump is good you can zip the line off the fuel filter, give the pump 12v and wait til it runs out of fuel... might take a while if its full maybe 30 minutes? I'm not sure but thats what i'd do if it didnt have much in it.
