sinkrun Posted May 11, 2010 Share Posted May 11, 2010 Does anyone know what years will interchange with my 89MJ? The wipers on my xj`s are much faster and smoother than the MJ and I need to do the bushings and was thinking I should either do a upgrade or just buy a new motor also. Link to comment Share on other sites More sharing options...
Wildman Posted May 12, 2010 Share Posted May 12, 2010 Off the top of my head, I'm going to say that your good up to '90, after that '91+, Chrysler went to the negative ground, which changed all the electrics in the Jeeps. If you change out the bushings, you will see a major improvement. With the worn out bushings, alot of slop is in the wiper arms, and kind of makes the wipers work really slow. Do you put this all back together, and then decide you need a new motor :dunno: I did one with the new bushings, and then decided that the motor needed replacing, so I opp'ed out for a used motor I had on the parts shelf, it did help some, so that's your call :hmm: Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 12, 2010 Share Posted May 12, 2010 Off the top of my head, I'm going to say that your good up to '90, after that '91+, Chrysler went to the negative ground, which changed all the electrics in the Jeeps.:hmm: :huh???: Link to comment Share on other sites More sharing options...
Geonovast Posted May 12, 2010 Share Posted May 12, 2010 As opposed to a positive ground? I'm fairly certain the wiper motor itself is the same. Link to comment Share on other sites More sharing options...
Pete M Posted May 12, 2010 Share Posted May 12, 2010 if your wires are corroded, cleaning up the connections of even swapping in new wires can make a huge difference too. Assuming the bushings aren't shot of course. Link to comment Share on other sites More sharing options...
sinkrun Posted May 12, 2010 Author Share Posted May 12, 2010 Did not take it apart yet, I am sure bushings are needed the wipers are going down past the window about 2". I will rebush it first and check the wires for corrosion as the motors are not cheap and the yards around here want darn near new prices. Link to comment Share on other sites More sharing options...
Wildman Posted May 12, 2010 Share Posted May 12, 2010 Off the top of my head, I'm going to say that your good up to '90, after that '91+, Chrysler went to the negative ground, which changed all the electrics in the Jeeps.:hmm: :huh???: :dunno: OK.......what year did they change the Hot > negative switching, as opposed to Hot switched to negative........Or have I been working with too many door controllers and losing it :nuts: BTW........had a real problem one today to deal with :headpop: Got it fixed with the "extra" relay added from the intercom's door REX :brows: Still had to swap out the power supply circuit board :( I think I'll go sleep some now........... Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 12, 2010 Share Posted May 12, 2010 The 5-pin connector changed in 92, but the wiper motor itself is the same 84-01. Neg ground. You can wire on the old-style connector to the new motor, and vice-versa by matching wire function, not the color codes. :cheers: Link to comment Share on other sites More sharing options...
