knever3 Posted May 11, 2010 Posted May 11, 2010 Well I got something new for the Jeep, I needed a ax-15 4wd trans and I found one. I got a great price on it so I just went ahead and picked it up. I have a few questions though. 1. I need a new hard line to the master cylinder, can I re-use the ms I have from my ba-10/5? 2. Should I look around for a external slave bell housing or is the one here fine? 3. The CPS on the new ax-15 is broken, can I use the one from my ba-10/5? 4. What should I replace before installing? Example seals etc.
Pete M Posted May 11, 2010 Posted May 11, 2010 the CPS will bolt right in. :thumbsup: If you go with a Mopar internal slave, it should last just fine. aftermarket ones are kinda hit or miss with longevity.
kro10000 Posted May 12, 2010 Posted May 12, 2010 If you have the means, I would definitely go external slave... Its SOOOO much easier to replace
