87 comanche Posted May 9, 2010 Share Posted May 9, 2010 lifted my xj 3" know when i give it gas or let off the gas i get noise and vibration could it be my u-joints? It was there before but not as loud. Link to comment Share on other sites More sharing options...
Lenard Posted May 9, 2010 Share Posted May 9, 2010 sounds very possible, have you looked at the joints yet? if the u-joint were already going bad the lift did not help them. oh and of course, :needpics: Link to comment Share on other sites More sharing options...
Automan2164 Posted May 9, 2010 Share Posted May 9, 2010 How did you lift it? Rob L. Link to comment Share on other sites More sharing options...
87 comanche Posted May 9, 2010 Author Share Posted May 9, 2010 sorry no pics i have tried before but can't get them downloaded. It is a 97 jeep country. I put a 3inch rustys offroad add a leaf suspension lift on it. i am hoping that it is just my u joints. I am thinking of taking the drive shaft out and having it balanced and new u joints put in. Link to comment Share on other sites More sharing options...
Backroads Posted May 10, 2010 Share Posted May 10, 2010 you can try by takin your front shaft out. if it stops then either the U joints are goin out, OR your driveshaft angle isnt correct. Maybe measure you pinion angle while your under there just so you know. Its worth a shot. I ended up right where you are and did the whole driveshaft rebuild first, just to find out it was my pinion angle all along. Link to comment Share on other sites More sharing options...
Automan2164 Posted May 10, 2010 Share Posted May 10, 2010 He's got where I was going... Just making sure you used a complete kit, and didn't jack up any pinion angles causing the vibe. Rob L. Link to comment Share on other sites More sharing options...
Pete M Posted May 10, 2010 Share Posted May 10, 2010 if the rear U-joints are still the originals, I'd start there. U-joints don't take well to changes in their operating angles. :( Link to comment Share on other sites More sharing options...
87 comanche Posted May 10, 2010 Author Share Posted May 10, 2010 Hey thanks guys. Called rustys since they sent me the wrong u bolts anyway and they said the same thing with the angle so they are sending my u bolts and a transfercase lowering kit $ 20 i'll give it a try. But they are the stock u joints so will be replacing them soon also. Link to comment Share on other sites More sharing options...
Pete M Posted May 10, 2010 Share Posted May 10, 2010 I would install new joints long before I lowered my trans crossmember. :thumbsup: Link to comment Share on other sites More sharing options...
Geonovast Posted May 10, 2010 Share Posted May 10, 2010 IMO, a T-case drop kit is going to make your problem worse. They're not practical for an XJ at only 3 inches. Do they make your rear U-joint angles better? Yes. Do they make your front U-joint angles better? NOooooo. They make them worse. Replace your U-joints. If you paid for that drop kit, send it back. If they sent it to you for free, sell it to someone who has a much bigger lift than you and actually needs it. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted May 10, 2010 Share Posted May 10, 2010 They're not practical for an XJ at only 3 inches. '97+ XJ's are MUCH more prone to driveline vibes than older era one's. 3" is the "gray" area on the '97+ models. Link to comment Share on other sites More sharing options...
87 comanche Posted May 11, 2010 Author Share Posted May 11, 2010 Gray area so I will always have a little vibe? What did you guys do to correct the angle shims? You think it will get a little better once the add a leaf breaks in? Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted May 11, 2010 Share Posted May 11, 2010 The correct solution is a Slip Yoke Eliminator (SYE) and CV style rear driveshaft. You can help eliminate vibes often with a TC-Drop and/or shims under your leaf packs to help get the angle's better. However this is just considered a "band-aid" solution. As stated prior; check u-joints first. Link to comment Share on other sites More sharing options...
87 comanche Posted May 11, 2010 Author Share Posted May 11, 2010 will do thanks :thumbsup: Link to comment Share on other sites More sharing options...
