Remove the bench seat
Push seat belts through, take 4 nuts off, unplug seat belt electrical buzzer connection, lift it out, get spacers off of bolts. You will need to pull the console and take the seat belts loose also if you plan on taking the whole carpet out. Oh, yea, remove the door sill covers, the kick panels, and probably the pillar trim also for ease of taking out and putting back in. If there is a back panel below the rear window, need to remove it also.
i feel for you man. i live by nashville in gallatin. i already pulled my seats and carpet and pressure washed the carpet. i let it dry then reinstalled it and everything looks gorgeous now :yes: i fixed my floor board rust while i was at it too :yes: i also changed all my oils due to the water. the truck needed all that stuff, but it sucks that i had to do it :ack: letl me know if you need anything
Yea, LOTTA work but worth it. When I bought my 'manche was wet inside. Had to pull everything. No rust, but to kill mildew used lotsa clorox and vinegar and scrubbed the youknowwhat out of the carpet. Let it dry about a week and reassembled.
Sweet Mary mother of Jesus.......it STINKS. The carpet and pad is out. I found some old cardboard box and sand paper under the carpet. It's drying out now. There's a little surface rust in a few spots but the wire attachment on the grinder should make short order of that. I'll put that black stuff over it. I hadn't thought about a rubber mat. That might work great. I could make a pattern then cut it to fit.
I found ants. Little black sugar ants. Sprayed that down. All in all, it's in pretty good shape. The floor pans are solid. I'm please. The bad....my Haynes manual is soaked. Not sure I can save it.
That's ok. Throw the haynes manual in the trash anyway. They are junk for MJs. The site you stumbled upon is ten times better than any book you can buy at Vato zone
The guys here are more knowledgable than any manual
