Hick Posted May 4, 2010 Share Posted May 4, 2010 About the load sensing valve? Mine leaks. Can someone give me a step by step on how to either repair, replace, or remove it? Link to comment Share on other sites More sharing options...
KYMJ Posted May 4, 2010 Share Posted May 4, 2010 I just removed mine. It won't be hard to find the procedure. In a nutshell: I ran a new line to the flexline from the front port of the distribution valve and plugged the bottom front port. Link to comment Share on other sites More sharing options...
Hick Posted May 4, 2010 Author Share Posted May 4, 2010 Did that make your rears lock up quicker? Link to comment Share on other sites More sharing options...
KYMJ Posted May 4, 2010 Share Posted May 4, 2010 I plan on an adjustable prop valve. However, the only time I've notice any problem is on a wet road. I was really surprised by that, so I might not add it. And I'm REALLY watching my tailgating. I'm really gun-shy after blowing a brakeline in a panic stop. Sure glad I fixed my emergency brake earlier this year. Link to comment Share on other sites More sharing options...
Hick Posted May 4, 2010 Author Share Posted May 4, 2010 When you say prop valve, do you mean the thing in the front after the master cylinder where all the lines split or the valve i asked about under the bed? Link to comment Share on other sites More sharing options...
kastein Posted May 5, 2010 Share Posted May 5, 2010 The former - the latter is either the Height Sensing Valve or the Load Sensing Valve depending on who's talking. Link to comment Share on other sites More sharing options...
Pete M Posted May 5, 2010 Share Posted May 5, 2010 sorta. the thingie up front where all the lines split off isn't actually a proportioning valve in our trucks, just a diverter. If you have any rear brake issues after removing the rear height sensing valve, you could try swapping an XJ prop valve in it's place. :dunno: Link to comment Share on other sites More sharing options...
Eagle Posted May 6, 2010 Share Posted May 6, 2010 sorta. the thingie up front where all the lines split off isn't actually a proportioning valve in our trucks, just a diverter. If you have any rear brake issues after removing the rear height sensing valve, you could try swapping an XJ prop valve in it's place. :dunno: DON'T DO IT! I know Pete means well, but I own multiple XJs as well as multiple MJs. I can assure you that a great many XJ owners take the O-ring and spring out of the XJ proportioning valve, which makes it work just like the MJ distribution block ... because the rear brakes on XJs with the OEM proportioning valve suck. It will NOT accomplish the one thing you would want it to do ... prevent rear wheel lockup in a panic stop. Link to comment Share on other sites More sharing options...
