brian Posted May 4, 2010 Share Posted May 4, 2010 noticed a change in the slopiness of my steering wheel. I had a lot of wiggle in it before which I tried to fix but was scared off by the inaccessablility of the knukle joints when I first tried . suddenly it has even more side to side and up and down slop. Has anyone ever had one break loose? 89 comanche 4.0 4x4 Link to comment Share on other sites More sharing options...
KYMJ Posted May 4, 2010 Share Posted May 4, 2010 Done it. Here's one write up: http://www.chevyasylum.com/column/tiltcol.html The pivot pin tool can be found at an auto parts store that carries Lisle Tools, I found one in my town for $8. Link to comment Share on other sites More sharing options...
brian Posted May 4, 2010 Author Share Posted May 4, 2010 Thanks KYMJ for the link. Always nice to know someone has accomplished what seemed undoable to me. Great write up Link to comment Share on other sites More sharing options...
KYMJ Posted May 4, 2010 Share Posted May 4, 2010 Yeah, it's doable, not easy, take your time and take pics as you go. There's a better site, but haven't found it yet. Link to comment Share on other sites More sharing options...
-600JeepMJ Posted May 4, 2010 Share Posted May 4, 2010 :agree: That is what I like about this club. someone has done it already and is willing to share the info Link to comment Share on other sites More sharing options...
KYMJ Posted May 4, 2010 Share Posted May 4, 2010 Here's the one I used: http://www.elcaminocentral.com/showthread.php?t=27192 Link to comment Share on other sites More sharing options...
brian Posted June 1, 2010 Author Share Posted June 1, 2010 I followed the links you guys provided and they were great help in getting down to the 4 bolts that had backed out in my steering column. Tricky stuff but I tightened them down and got everything back togetyher. all looked good til the next day when the whole darn thing suddenly was even sloppier than before! I suspect when the bolts were lose and the column was moving around a lot something must have cracked from fatigue.Then after I tightened up the bolts the whole thing gave way. Anybody been down the column past the 4 bolts? Is it worth going back in there or should I just rip the whole thing out and get a used column? :wall: thanks Link to comment Share on other sites More sharing options...
64 Cheyenne Posted June 1, 2010 Share Posted June 1, 2010 Here's another good one: http://www.fiero.nl/forum/Forum2/HTML/088020.html Actually, IMO this one rates A+. I copied it for future reference, even though my tilt columns work fine. That is if I can keep my daughter from using the wheel as a grab handle (Bad habit needs to be broken) to get into the cab. Link to comment Share on other sites More sharing options...
jimoshel Posted June 1, 2010 Share Posted June 1, 2010 Here's another good one: http://www.fiero.nl/forum/Forum2/HTML/088020.htmlActually, IMO this one rates A+. I copied it for future reference, even though my tilt columns work fine. That is if I can keep my daughter from using the wheel as a grab handle (Bad habit needs to be broken) to get into the cab. Try putting one of DJM'S goobers on it. The steering wheel that is. Link to comment Share on other sites More sharing options...
dakal Posted June 2, 2010 Share Posted June 2, 2010 Here's another good one: http://www.fiero.nl/forum/Forum2/HTML/088020.html Actually, IMO this one rates A+. I copied it for future reference, even though my tilt columns work fine. That is if I can keep my daughter from using the wheel as a grab handle (Bad habit needs to be broken) to get into the cab. good grief: that is one detailed site. i had to lay down after reading part of it. Link to comment Share on other sites More sharing options...
brian Posted June 2, 2010 Author Share Posted June 2, 2010 Thanks guys. another good link. Yeah.. I think using the steering wheel for a grab bar is the problem. I found that the metal shaft just below the 4 lose bolts had stress cracked while the blots were lose. Most likely from my kid doing the grab bar thing. :grrrr: All seemed good after I tightened the bolts... :headpop: but after he drove it that night the metal column was mysteriously busted in two the next morning. I'm about to bust something in two myself....over my kid's head :mad: Another trip to the junkyard this morning got me a steering column from a 87 mj. for 40 bucks. So I'm tossing the old one and installing the new one. If all goes well I'll be drivin'my little yellow mule to the pub by cocktail hour. thanks all Link to comment Share on other sites More sharing options...
