alex_and_sean Posted May 3, 2010 Posted May 3, 2010 Ok guys, I have three questions: 1. my horn stopped working. I replaced the relay under the dash in the fuse panel and the horn, and no dice .... Using my DVM, I get no voltage at the terminal. I have tried trouble shooting this for the last couple of weeks to no avail. Got any suggestions? 2. Similar electrical problem with turn signals .... Hazards work fine, right signal works ok, left extremely slow - solid if it is cold outside. Again, replaced relay with no improvement. Could it be a bad stalk? Any other ideas? 3. Adding a fan. I think I need to add an electrical fan to minimize over heat risk while wheeling. I searched the site and found some posts on the subject but I can't seem to find what fans people are putting in and where they got them. Any advice? Hoping that once these are done, I can move onto e-brake cable fix and then some wheeling! Thanks Sean
Pete M Posted May 3, 2010 Posted May 3, 2010 check your left side turn indicators for corrosion in the sockets. :thumbsup:
JACKED88 Posted May 3, 2010 Posted May 3, 2010 Did both your horn and blinker problem start at tha same time? Check your grounds under tha dash. That could be your blinker prob as well.
Silver88 Posted May 3, 2010 Posted May 3, 2010 I had a horn problem last year. Turned out it was the contacts under the horn button on the steering wheel. Cleaned them up, good bye problem. :brows:
