power steering
For what? If youre referring to a 2.5, then, no they don't... I had to make one for mine... used one frm a late model Caravan....One from a Chrysler 300 would also have worked..... This is assuming you had a remote resevior. If you have a 4.0 I think they are still made... some aftermarket pumps even have them built onto the pump already. Good luck!
I just converted mine to power last weekend.
the reservoir from the donor was broken so i searched the yard and found a good replacement on a BMW,lots of cars use remote reservoirs just look around and you will find something close.
When I converted mine, I bought a pump from wherever, but couldnt find an aftermarket pulley or resevior. At the dealer, I found Chrysler restoration parts carried the pulley still, but no resevior, so I bought the pulley, and started looking around for a res. I knew the caravan one would be close and bought one and made it work, built a bracket to mount it to, and connected the hoses. Has worked fine for about a year now.. Good luck!
