Brenton Posted April 17, 2010 Share Posted April 17, 2010 My 88' MJ has the manually adjusting door mirrors (I'm assuming just like every comanche). What I want to know is if any of them came with the little knob for adjusting them without rolling down the window and actually adjusting the glass. :shake: If not, is it a direct or simple swap from a donor XJ, and if so, do I need to look for a certain year? :hmm: Thanks!!!! :cheers: Link to comment Share on other sites More sharing options...
jimoshel Posted April 17, 2010 Share Posted April 17, 2010 Some did. It was an option. Any '80's XJ will fit a MJ. Link to comment Share on other sites More sharing options...
Pete M Posted April 17, 2010 Share Posted April 17, 2010 My 88 did. never did work. I still had to roll the window down to make adjustments. :( Link to comment Share on other sites More sharing options...
mnkyboy Posted April 17, 2010 Share Posted April 17, 2010 I installed some on mine from an XJ,direct swap Link to comment Share on other sites More sharing options...
jimoshel Posted April 17, 2010 Share Posted April 17, 2010 I got two that works OK, '87 &'88. On the '89 I got tired fooling with it and jammed a piece of cardboard between the glass and the frame. It works. Link to comment Share on other sites More sharing options...
