Hubbell Posted April 17, 2010 Posted April 17, 2010 Has anyone installed a dual battery setup in an mj and if so where did you put the second battery? Pics would be good to. Also any tips on the hookup that uses some junkyard parts would be good to. Thanks Chris :cheers:
Pete M Posted April 17, 2010 Posted April 17, 2010 do you have a need for 2 batts? I put one in the bed, though i haven't hooked it up to anything. But it is within jumpercable range. :D
Hubbell Posted April 17, 2010 Author Posted April 17, 2010 Yes I'm in the process of mounting my winch. I've had the dual system on my old bronco and it definately saved my butt before. There just seems to not be enough room under the hood. The only spot that I can see is where the air box is meaning an air intake upgrade would be necessary.
HOrnbrod Posted April 17, 2010 Posted April 17, 2010 Yes, that's what most use, the airbox space. Then a battery box from a RHD XJ will fit in. There's some writeups on this in NAXJA.
LEAD_NOT_FOLLOW Posted April 17, 2010 Posted April 17, 2010 Mean Green used to make a dual battery kit (however they have discontinued it in the last year or so). Here is a pic to give you an idea of what it looks like installed.
Hubbell Posted April 18, 2010 Author Posted April 18, 2010 Well after alot of searching I think I have found the write-up that is the most economical and easiest to understand. http://www.junkyardgenius.com/charging/dual01.html I hope this link might help someone else looking for the same answers. Also thanks for the pics that one of the engine bay will be a good reference.
