Has anyone installed a dual battery setup in an mj and if so where did you put the second battery? Pics would be good to.
Also any tips on the hookup that uses some junkyard parts would be good to.
Thanks Chris :cheers:
do you have a need for 2 batts?
I put one in the bed, though i haven't hooked it up to anything. But it is within jumpercable range. :D
Yes I'm in the process of mounting my winch. I've had the dual system on my old bronco and it definately saved my butt before. There just seems to not be enough room under the hood. The only spot that I can see is where the air box is meaning an air intake upgrade would be necessary.
Yes, that's what most use, the airbox space. Then a battery box from a RHD XJ will fit in. There's some writeups on this in NAXJA.
