sinkrun Posted April 12, 2010 Share Posted April 12, 2010 My manche is draining my the battery anyone know any known culprits?? I have not messed with anything in the wiring in the last year. Link to comment Share on other sites More sharing options...
Pete M Posted April 12, 2010 Share Posted April 12, 2010 do you have a multimeter that reads amperage? Link to comment Share on other sites More sharing options...
sinkrun Posted April 12, 2010 Author Share Posted April 12, 2010 Not here at the house now will have it tuesday. Link to comment Share on other sites More sharing options...
Pete M Posted April 12, 2010 Share Posted April 12, 2010 You can use it inline at the battery and then have someone pull fuses one at a time until the draw goes away. that'll narrow it down a bunch. :D Link to comment Share on other sites More sharing options...
lostissues Posted April 12, 2010 Share Posted April 12, 2010 be careful with that, a lot of multimeter's will have an internal fuse and could blow that if you hook it up in line. Â if you want to look up how to test it do a search for "parasitic drain test" Link to comment Share on other sites More sharing options...
Pete M Posted April 12, 2010 Share Posted April 12, 2010 the only meter I'm familiar with has a 10 amp ammeter. that's one heck of a draw to blow that fuse. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 12, 2010 Share Posted April 12, 2010 Pete's correct, it's very seldom (like never) to have a 10A draw w. the key out, doors shut, and all devices off. I usually pull all the fuses, hook up the multimeter in series w. the neg battery cable and ground, then stick the fuses back in one by one until you see a draw. Usually it's no more than 500 ma. Last Jeep I had drawing the battery down overnight was caused by an internal short in the radio - it was shorting out the radio memory voltage. :eek: Link to comment Share on other sites More sharing options...
sinkrun Posted April 13, 2010 Author Share Posted April 13, 2010 Thanks for the ideas I will see what I can find tuesday and post back. Link to comment Share on other sites More sharing options...
sinkrun Posted April 13, 2010 Author Share Posted April 13, 2010 Glove box light the latch was loose and out of place (again) so the light was staying on. Link to comment Share on other sites More sharing options...
Pete M Posted April 13, 2010 Share Posted April 13, 2010 glad to hear it was something simple. :thumbsup: Link to comment Share on other sites More sharing options...
