Aftermarket full leaf packs ?
SURE ENOUGH!!!
There is a number of options!!
Hell Creek is a member here and has what you need.
Motion Off road is also here and aslo has a couple to choose from.
I have a set of ALCAN leafs, and you could have a set built from a local shop.
Last choice would be Rustys offroad.
CW
Ok looks like my local spring shop is my only answer then . I was hoping one of the big lift kit companys made them , so I could get them local , shipping to Canada sux . I broke both main leafs wheelin on a trail here called the " Curse " yesterday
According to this chart:
http://littlekeylime.com/MrN/mrnimages/leaf_springs.png
Waggy/J truck rear leafs & MJ's both are 57" long, with similar pin offset.
I question this, but MrN is usually right on with his info. :dunno:
I'm not saying they'll bolt right in, but there may be some other options (like Waggy leafs below an MJ main leaf).
i have a broken main spring on my 90 elminator and i priced at getting just the main spring made and it $500 for the one leaf!!!! i can get both side full replacement packs from heelcreek for the much. i don't know up there, but around me the spring shops are a rip off.
Josh
MrN is correct. Both springs have main leaves that measure 57" long. They both have a center pin spacing of 26" X 31", and they both use 9/16" I.D bushings on the anchor and shackle bushings, so you could use some of the leaves to repair yours. Keep in mind though that a full-size Jeep is much heavier than our trucks, so you probably would not want to use all of the leaves. :thumbsup:
-Tom
-Tom
Thank you for the timely & informative post. :thumbsup: :thumbsup:
:cheers:
