asm4mcc Posted March 31, 2010 Share Posted March 31, 2010 well i just put my tranny in and drove it around for like 3 days and then it started making a noise when i push the clutch in all the clutch parts are brand new also this is my first m/t swap thanks 97 ax15 Link to comment Share on other sites More sharing options...
jimoshel Posted March 31, 2010 Share Posted March 31, 2010 Tear it apart and look at it BEFORE you really tear something up. I would blame the throw out bearing first with the pressure plate(fingers) next. Link to comment Share on other sites More sharing options...
Geonovast Posted March 31, 2010 Share Posted March 31, 2010 If it was fine for 3 days, and the throwout bearing was new, I would be it's not that. My bet would be either loose bellhousing bolts, or loose pressure plate bolts. Can you describe the noise better? Clutches/transmissions can make all kinds of different noises. Link to comment Share on other sites More sharing options...
Pete M Posted April 3, 2010 Share Posted April 3, 2010 Is it a rattling noise? more of a bolts-in-a-soup-can noise? Link to comment Share on other sites More sharing options...
asm4mcc Posted April 21, 2010 Author Share Posted April 21, 2010 it was lose bell houseing bolts Link to comment Share on other sites More sharing options...
