ax 15 clutch line
You could try a compression fitting. It might not hold up to the pressure, but I think Pete M used one on a brake line once and got away with it, so it's worth a try.
noooooooo no no no no no no no. They should never EVER be used on brake lines. The pressure is too high.
I used a 1/4"to 5/16" adapter compression fitting for connecting my external slave to my original 88 metal line. ti works great for clutch lines since there's far less pressure in there.
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
