tallon2064 Posted March 20, 2010 Share Posted March 20, 2010 Does anyone know the size(diameter and length) of the lower trackbar bolt? Looking to change mine (trackbar) and want to get a replacement bolt. Would really like to get before disassembly so I have it on hand. Lots of threads on the trackbar but none list the bolt size, :dunno: atleast none I have found. I have an 88 2wd with a 4.0. Link to comment Share on other sites More sharing options...
Wildman Posted March 21, 2010 Share Posted March 21, 2010 upper trackbar bracket bolts = M12x1.75, ~1.75"long lower trackbar bracket nuts/motor mount studs = M12x1.75 You can find the rest of the bolts/threads here - viewtopic.php?f=9&t=11380&start=30 Mostly on page 3, where Cherokee spent the time to list all the bolts as he was re-assembling his MJ :yes: Link to comment Share on other sites More sharing options...
tallon2064 Posted March 26, 2010 Author Share Posted March 26, 2010 Thanks, but I am looking for the bolt size of the lower(axle side) that actually fastens the track bar to the axle, the one with nut that has nasty tab Link to comment Share on other sites More sharing options...
Eagle Posted March 26, 2010 Share Posted March 26, 2010 I know it's metric. Pretty sure it's 10mm but I don't recall the length. Link to comment Share on other sites More sharing options...
cherokee Posted March 29, 2010 Share Posted March 29, 2010 it's m10x1.5x65mm or so I guess I missed one. If possible get a hardened flange bolt in m10x1.5x60mm (I never found a 65mm long bolt in the hardware store). If you can't find a flanged (built in washer) bolt, find a normal one and get a hardened washer to go with it. Don't forget that metric hardness ratings are different so you're looking for a 10.9 rather than the 8.whatever. Last time I bought a couple cost was a bit over $2/pc. The bolts that Wildman is referring to are the bolts used to hold the upper trackbar/motormount bracket to the frame. Link to comment Share on other sites More sharing options...
tallon2064 Posted April 17, 2010 Author Share Posted April 17, 2010 Thanks for the info been awhile since I checked but thanks for the input. :waving: Link to comment Share on other sites More sharing options...
