kyleag89 Posted March 17, 2010 Posted March 17, 2010 Ok so I have googled this and found that I can rebuild them myself. I was wondering if anyone knew where to buy the O-ring kits and the fuel line clip/o-ring repair kit? Thanks
kro10000 Posted March 18, 2010 Posted March 18, 2010 Auto parts stores... OReillys anyway I dunno about any others
kar120c Posted March 18, 2010 Posted March 18, 2010 If you want to get them professionaly serviced, I'd highly recommend http://www.witchhunter.com/. I used their service about year ago to clean my 01 Cherokee injectors and replace o-rings. Most of them were fairly good except for one which was way out of spec. Helped my idle greatly.
mfpdm Posted March 18, 2010 Posted March 18, 2010 For a little over a $100 you can get a set of rebuilt and flow matched ones from Precision Auto Injectors. You can even get the 5.0 injectors which will improve performance and mpg for a little more. Here's the link: http://www.precisionautoinjectors.com/main.sc :cheers:
one_bad_MJ Posted March 18, 2010 Posted March 18, 2010 advance auto parts has the 0-ring kits 7.99 for them but i found out that Dorman makes a universal 0-ring kit they have fat blue o-rings in them and they seal tighter use Vaseline to lube them when installing and they won't rip.
HOrnbrod Posted March 18, 2010 Posted March 18, 2010 For a little over a $100 you can get a set of rebuilt and flow matched ones from Precision Auto Injectors. You can even get the 5.0 injectors which will improve performance and mpg for a little more. Here's the link: http://www.precisionautoinjectors.com/main.sc :cheers: Paul, what bothers me about this site is that they don't give p/n's, flow rates, and the pressure rating of the injectors. I know exactly what I want (refubished Mopar grey top 96-99 p/n 53030778, 23.2 lb/hr @ 49psi). Their site lists one injector for like 88-92 Jeeps. Not hardly true. I don't want to go thru another tuning process for the stroker. :(
kyleag89 Posted March 19, 2010 Author Posted March 19, 2010 Thanks for all the help guys... I will most likely end up doing this myself with the rebuild kit. All my money is going into the body right now.
MJ is dead Posted March 19, 2010 Posted March 19, 2010 You clearly don't know the jeep rule. "Don't just fix it, make it better"
smithe1811 Posted March 19, 2010 Posted March 19, 2010 You can even get the 5.0 injectors which will improve performance and mpg for a little more. Here's the link: http://www.precisionautoinjectors.com/main.sc :cheers: X2
mfpdm Posted March 21, 2010 Posted March 21, 2010 Paul, what bothers me about this site is that they don't give p/n's, flow rates, and the pressure rating of the injectors. I know exactly what I want (refubished Mopar grey top 96-99 p/n 53030778, 23.2 lb/hr @ 49psi). Their site lists one injector for like 88-92 Jeeps. Not hardly true. I don't want to go thru another tuning process for the stroker. :( They use to have a lot more info on their website. Must be the economy. In fact I don't even see the 5.0 injector upgrade deal for Jeeps. I guess you could contact them and they would tell you what p/n's they use or you could request them use a specific p/n. Anyhow, I went with them after a few on here had good success with them. I believe Jeff was one. They send a sheet with the injectors with the flow rate and psi that they tested at. :cheers:
