charte07 Posted March 12, 2010 Posted March 12, 2010 i'm new to this site and i just recently got a comanche. its an 86. 2.8l. 5 speed. 4x4. i locked the engine up about a week ago. and its my only way of getting around. so i'm not sure what to do. i was told a 3.4 or 3.1 could bolt in exactly. but i'm a little short on cash so i'm not sure what to do. any suggestions anyone?
Eagle Posted March 12, 2010 Posted March 12, 2010 The 2.8 liter Jeep engine is a GM engine. Jeep bought them from Generous Motors. The GM 3.1L and 3.4L V6s are built on the same block, so they are almost bolt-in replacements ... and much better engines. You will have to use the Jeep manifolds and accessory brackets. And the 2.8L is externally balanced, which means there's an eccentric heavy spot on the flywheel. By the time GM developed the 3.1L and 3.4L they had figured out how to balance the engines internally, so you'll need to have the flywheel "neutral balanced."
charte07 Posted March 12, 2010 Author Posted March 12, 2010 other than manifold, accessory brackets, and flywheel i won't have any problem? is it possible to use the flywheel from the 3.4 or do i need to use the original flywheel just balanced?
dasbulliwagen Posted March 12, 2010 Posted March 12, 2010 Its best to use your original, that way you know it will work with your trans.... It won't cost much of anything to have a machine shop neutral balance yours, and surface it at the same time!
kro10000 Posted March 12, 2010 Posted March 12, 2010 And, correct me if I'm wrong, but doesnt the motor need to come from a car that had the engine mounted longitudinally, not transversely?
charte07 Posted March 12, 2010 Author Posted March 12, 2010 thanks. i really appreciate it. i'm probably gonna start early next month with the swap. i need to save up a little for unexpected things. i'll post whatever i do and any questions i have
Pete M Posted March 13, 2010 Posted March 13, 2010 Early 90s v6 Camaro/firebird or S-10 should have the 3.4/3.1 in it. You'll need to add in a small electric fuel pump, as the later engines do not have a boss for the mechanical unit. It's just a carb though, so you don't need a high pressure pump (like for EFI).
