veritas4156 Posted March 10, 2010 Share Posted March 10, 2010 Alright, so I went to a local auto parts store and picked up a couple wheel u joints for my truck. They gave me a NEAPCO 1-0174 but it didn't quite fit right, regardless, i broke the u joint putting it in and slightly bent the yoke. Called up competing auto parts store and they said the proper part number for these is NEAPCO 1-0297. The problem is, the bearing caps seemed to be the right size and the center cross was too big, but on the 1-0297 the bearing cap is bigger. Any idea what my issue may be? Factory D30 w/vacuum disco in the front, lemme know if you need more info. Link to comment Share on other sites More sharing options...
james750 Posted March 10, 2010 Share Posted March 10, 2010 A couple different ujoints were used in the 30, yours takes the 297x joint. the other joint was probably for a newer 30 with the 760x joint Link to comment Share on other sites More sharing options...
Geonovast Posted March 10, 2010 Share Posted March 10, 2010 His should be old enough to need the 260 joints. Take your old U-joint into the parts store and make sure you get the right one. Link to comment Share on other sites More sharing options...
Blue XJ Posted March 10, 2010 Share Posted March 10, 2010 A couple different ujoints were used in the 30, yours takes the 297x joint. the other joint was probably for a newer 30 with the 760x joint The 297 and 760 were interchangeable, the 260 is the smaller size that he would need if its a stock axle. They didn't switch to the 297 size in XJ's until 96. However, most ABS equipped D30's did get the 297 sized shafts regardless of year I believe. Link to comment Share on other sites More sharing options...
veritas4156 Posted March 10, 2010 Author Share Posted March 10, 2010 They gave me the rght joint the first time, but it was defective. It had a burr on the cross that prevented a cap from going on all the way. Thanks for the help. It was the neapco 10174 in case anyone goes through this in the future, which is the smaller one. Link to comment Share on other sites More sharing options...
