How much lift can you do to the front of an MJ before you need to start swapping out things other than the shocks or run the risk of DW?
I wouldn't go higher than 2" with stock arms, brake lines, swaybar links etc.
:agree: Get 2" spacers up front, extended greaseable shackles for the back, and you're done. Spacers and shackles can be found on ebay, for less than $100 (altho most likely not from the same seller). This is the lift I was thinking of putting on my MJ, but since I put an airbag helper kit on the back, I'm going to leave it at stock height for now.
