james750 Posted March 8, 2010 Share Posted March 8, 2010 I've been searching for vac leaks on my truck. On the right side of the throttle body (passenger side), there are 2 vacuum ports the bottom one has a line running to the MAP sensor, but the top one is empty. What is supposed to be hooked up to the top vac port? Quote Link to comment Share on other sites More sharing options...
-600JeepMJ Posted March 8, 2010 Share Posted March 8, 2010 maybe a test point? mine is pluged off Quote Link to comment Share on other sites More sharing options...
64 Cheyenne Posted March 8, 2010 Share Posted March 8, 2010 Actually, it is a test port. It's designed to "test" Jeep owners to see if the'yre paying attention to what is going on with their vehicle. Not really, It's "blind", meaning the hole doesn't go all the way through. I put a small screw in mine because...... :dunno: Quote Link to comment Share on other sites More sharing options...
ParadiseMJ Posted March 8, 2010 Share Posted March 8, 2010 Not really, It's "blind", meaning the hole doesn't go all the way through. I put a small screw in mine because...... :dunno: It's just a "keeper" hole to align the connection correctly. Just to help hold it in place. There's really no need to plug it as it's already "plugged" in the casting. Quote Link to comment Share on other sites More sharing options...
vaquaro Posted March 8, 2010 Share Posted March 8, 2010 That second port goes to the CCV grommet on the valve cover on my 2.5 , you have found your vacuum leak :clapping: Quote Link to comment Share on other sites More sharing options...
ParadiseMJ Posted March 8, 2010 Share Posted March 8, 2010 On the 4.0 - the ONE port goes to the MAP. The CCV hose goes to the intake manifold. Quote Link to comment Share on other sites More sharing options...
vaquaro Posted March 8, 2010 Share Posted March 8, 2010 On the 4.0 - the ONE port goes to the MAP. The CCV hose goes to the intake manifold. Sorry , didn't mean to spread dis-information :dunce: Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
