nitroxsteve Posted February 15, 2010 Share Posted February 15, 2010 I need a header panel for my"88" I also need a good bench seat any color is fine I plan to recover it. I'm in North Carolina but travel all over the east coast for work. Thanks, Link to comment Share on other sites More sharing options...
mfpdm Posted February 15, 2010 Share Posted February 15, 2010 If you make it up to Hampton Roads VA, I'll give you a bench seat. Only reason I held onto it was that it was solid and the springs were good. It will need recovered and will need your floor brackets. Yours for the taking. Â :cheers: Link to comment Share on other sites More sharing options...
nitroxsteve Posted February 16, 2010 Author Share Posted February 16, 2010 If you make it up to Hampton Roads VA, I'll give you a bench seat. Only reason I held onto it was that it was solid and the springs were good. It will need recovered and will need your floor brackets. Yours for the taking. :cheers: When I did a map quest for Hampton Roads VA it shows it in the middle of the Chesapeake Bay, do you live on a boat? I don't have any plans to be in that area soon, but I never know when my schedual will change.  Thanks, Link to comment Share on other sites More sharing options...
mfpdm Posted February 16, 2010 Share Posted February 16, 2010 If you make it up to Hampton Roads VA, I'll give you a bench seat. Only reason I held onto it was that it was solid and the springs were good. It will need recovered and will need your floor brackets. Yours for the taking. :cheers: When I did a map quest for Hampton Roads VA it shows it in the middle of the Chesapeake Bay, do you live on a boat? I don't have any plans to be in that area soon, but I never know when my schedual will change.  Thanks,   :rotfl2: Not anymore, I retired from the Navy. :rotfl2:  I'm in Cheaspeake, 23320. It's just hanging out in the garage so if you don't get one by the next time your this way, you can have it.  :cheers: Link to comment Share on other sites More sharing options...
shelbyluvv Posted February 16, 2010 Share Posted February 16, 2010 I have a header panel just north or Atlanta. It is complete and has the factory wiring for fog lights. Link to comment Share on other sites More sharing options...
nitroxsteve Posted February 16, 2010 Author Share Posted February 16, 2010 I have a header panel just north or Atlanta. It is complete and has the factory wiring for fog lights. How much? Link to comment Share on other sites More sharing options...
Rymanrph Posted February 19, 2010 Share Posted February 19, 2010 I have a header panel that is slightly cracked across the top, but can be repaired. I have a bench seat back too(I stole the mounts for my bucket seats). I think there is a bench in the Comanche at the Pull a Part, could be a good option for you. Link to comment Share on other sites More sharing options...
nitroxsteve Posted February 21, 2010 Author Share Posted February 21, 2010 I have a header panel that is slightly cracked across the top, but can be repaired. I have a bench seat back too(I stole the mounts for my bucket seats). I think there is a bench in the Comanche at the Pull a Part, could be a good option for you. Â Â Thanks, I went and got the seat from the pull a part today, ($35.00) it was actualy in great shape. I took it to the car wash on the way home and cleaned it up.I also so pulled the park brake assembly off, mine was stripped out. My header panel is repairable just didnt want to fool with it, there is a good one on a cherokee at the pull a part I'll probably head back over this week and pull it off. Link to comment Share on other sites More sharing options...
