What do the factory fog light plugs look like?
I wanted to add some Kc's/Hellas on the front of the XJ (90 Laredo) and I THOUGHT that the plug behind the grill was just for that (although I didn't have a switch for the dash). After some digging I was told that that connector was for the OH console outside temp sensor/sender.
Since I didn't have one, they were available on a 1990 (the OH console) I was also told that Jeep put the wiring there on all models "in case" the factory/customer wanted to add the option (kind of like having 2 TPS connectors for auto or stick option) This is second hand info, but may be useful.
The top one is for the horn (assuming you have a single tone instead of dual tone).
My horn is already plugged in and this plug is on the passenger side.
I believe the dual tone is achieved with 2 horns, one pass side and one drives side. so that is a horn plug, just a second horn plug.
I'll have to take that picture with me next time I'm at the JY and see if I can pull it from one of the XJs.
It's the complete front lighting wire harness. The ten pin connector disconnects somewhere around the air box. It's very easy to pull.
