another where does this wire go?
i'm trying to figure out where this wire goes. it goes to a sensor on the drivers side of the block. it is wrapped up along with 2 other wires. those 2 wires go into the plug for the sensor and this one is just hanging out all alone. anybody know where it might go?
Wires that have a "foil" wrapping, and a bare wire are called "Shielded" wires, used in the electronic field. The bare wire is to be grounded, and the foil is just to protect the primary wires from interference.
The reply you got from naxja is correct.
Only one end of the bare wire needs to be grounded, the other end, like at the knock sensor, just wraps around the foil. In your case, the wire may have just came undone.
  • 5 months later...
X2 on what wildman said - if you cut open a spare computer USB cable or similar, you will find the same thing. They do that because it is darn near impossible to solder well to the aluminum foil shielding, so they just stick a bare wire in next to it and solder to that instead when needed :thumbsup:
The things you learn as a professional nerd...
