brake light problem?
MJs have a connector in the wire harness just behind the driver's side rear tire. It is notorious for corroding inside and may need to be cleaned or replaced. I had to replace mine in the 88 and found a generic connector at the parts store.
also make sure no rodents have climbed up and chewed on the wiring going to the lights, i had that problem with a dakota i had! no only did the dam thing chew through the brake wiring in back but also chewed through some in the engine compartment for the ignition! :mad:
