Lighting Inquiry
Trying to run down a problem I'm having with my son's "new"
$300 Comanche. The headlights, turn signals, and brake lights
work, but I can't get the taillights, parking lights, or backup lights
to come on. We have checked and replaced all the bulbs,
been through the fuses and cleaned the ground behind the
driver's side taillight. All to no avail. I might add that We're
replacing a fender and the header panel, and while I had good
access to the wiring, I swapped the headlight harness from the
donor Cherokee. The wiring for the fog lamps was already on
that one and I figured that if he ever wants to add fog lamps,
the wiring will already be there. But I don't see how that could
possibly be part of the problem since that is only one plug, and
the headlights and turn signals work properly. Any suggestions
will be thoroughly investigated and greatly appreciated!
its right near the gas tank behind the rear tiers. goodluck :thumbsup:
No.......It's just inside the rear apron, on the left side, near the LH frame rail.
That connector has 4 wires to it
18 BR = RH stop/turn
18 GY/BK = LH stop/turn
18 BR/WT = Backup
18 DB = Parking lamps
There is also a connector above the parking brake, on the LH kick panel, but if that was a problem, the fuel pump would not be working.
You could have a problem with the wire where it runs behind the fuel tank, it could be pinched or corroded in that area. Check off the connector first, and back trace.
18 BR/WT = Backup
oh opps . on my jeep its by the rear end of my gas tank. but i may have moved it at some point
  • 3 weeks later...
I'm finally able to get back on this lighting problem again. I have gone through all the
bulbs, replaced all the fuses, the ground behind the drivers side tail light is o.k., and
the connector in front of the gas tank is in fine shape. Seeing as I have brake lights,
turn signals, emergency flashers and headlights, but no parking lights or tail lights, is a
bad light switch itself out of the realm of possibility?
Could be the switch, I'd check the connection on that.
Other common problem areas are if a previous owner spliced in a trailer light wiring harness in the back and messed things up.
Or, if it's a manual, the reservoir on the firewall is notorious for leaking into the cab, behind the fuse panel, and can cause a whole host of electrical gremlins back there.
If you have front parking lights and headlights, the switch is not the problem.
Have you replaced the bulbs? Parking lights and taillights are the same thing, using the lower brightness filament in each bulb. It's possible that new bulbs might cure it.
I have signal lights and headlights, but no parking lights front or back, nor any tail lights.
It wasn't the switch. Just got through replacing it. I do believe there
has been a trailer light pigtail hacked into the wiring. Guess I'll start
disecting that next. Thanks for your responses guys!
One other quick thought -
Double check that you have the correct bulbs. I remember when I first got my MJ, I relied on the catalog up at the parts store to pick out my new bulbs, and the info wound up being wrong (maybe it was for a XJ instead of an MJ, or maybe I just made a boneheaded mistake) But anyways, I wound up with single filament bulbs where double filament bulbs were supposed to be, and it drove me nuts trying to diagnose the problem until I discovered the error.
Check the fuse panel. The headlights use the built-in circuit breaker in the switch, but IIRC the parking lights are fused on the panel. If the fuses look good, get a test light or multimeter, turn the light switch to parking lights, connect the negative probe to a known good ground and check to verify that you have power to the socket (or not).
"Eagle" Check the fuse panel. The headlights use the built-in circuit breaker in the switch, but IIRC the parking lights are fused on the panel. If the fuses look good, get a test light or multimeter, turn the light switch to parking lights, connect the negative probe to a known good ground and check to verify that you have power to the socket (or not)
The fuse was good and I had 12 volts to the panel, but upon further inspection, the spring clip
on one end of the parking light fuse block had been spread apart and wasn't making contact with the fuse.
A little tightening up of the clip, and I now have parking lights and tail lights!!!
Thanks for heading me in the right direction Eagle!!!
  • 1 month later...
I beleieve that a previous owner spliced in a trailer light wiring harness in the back and messed things up. but how would i go aabout fixing that?
