Geonovast Posted January 23, 2010 Posted January 23, 2010 I'm soon to be getting a dirt cheap 29 spline 8.25, and I plan on rebuilding the thing before putting it in anything. Basically have a few questions.. Carrier break: This axle has 3.55. I would like to go to 4.10. Same carrier, or no? Axle shafts: I know the factory 29 spline shafts are pretty stout, but I wouldn't mind putting some slightly stronger ones in and using the factory shafts as spares. Locker: I would really prefer selectable. I like as little automatic-ness in my vehicle, and I would prefer it either locked or not, no maybes. Any 8.25 experts out there? I know some of you will say just find a D44, and if I come across one before I start buying up parts I'll probably go with that.
kar120c Posted January 23, 2010 Posted January 23, 2010 You don't need a new carrier. Not sure about the shafts, I'm sure someone probably has some stronger ones available. As for the locker, nothing but good reviews about ARB. Not sure if I'm going to put one in my 8.25...still undecided myself. Pricey though.
1991MJPioneer Posted January 23, 2010 Posted January 23, 2010 I've got a 29sp 8.25 sitting in my garage...got it dirt cheap too....unfortunately it came out of a 97 2wd with AX15 so 3.07 gears....I looked at shafts once for the 8.25...Superior makes stonger shafts for it. Yukon did too....
johnnyc Posted January 23, 2010 Posted January 23, 2010 I built an 8.25 that was in my two XJs. Superior 4.56 gears, No-Slip locker, Superior 29-spline shafts, ZJ disc brakes, BTF cover. It worked flawlessly. I didn't have to, but I got a D44 cheap and built that up similarly. I very well could've just kept the 8.25.
mvusse Posted January 23, 2010 Posted January 23, 2010 No carrier needed for 4.10 gears, BUT Any selectable locker will have/be it's own carrier, so the point is moot.
Blue XJ Posted January 23, 2010 Posted January 23, 2010 Not an expert, but I have a 29 spline 8.25 in my truck, I swapped it into my XJ when I had it too. I picked up a Powertrax NoSlip for it originally, then grabbed some ZJ disc brakes from a D35 at the junkyard. The brakes swapped right over except for needing to enlarge a couple holes on the caliper brackets. Never had a problem with stock shafts when I had 33's. I upgraded to 35's now, so I grabbed a set of Alloy USA shafts pretty cheap, and my pinion bearing went out, so I switched to an ARB when I got new bearings/gears installed. I have ran Yukon gears, they ended up getting a lot of gear whine after a few years. I just had some Precision gears installed, haven't ran them yet, so no comment. I do have my old Powertrax No Slip if your interested in it. There is no carrier break for this axle either, just if you go to 4.56 gears you have to grind off 1/2 of a tooth to install the cross pin in the carrier.
Geonovast Posted January 24, 2010 Author Posted January 24, 2010 Thanks for the info guys, I'll have to check out that stuff. Good to know there's no carrier break, Any selectable locker will have/be it's own carrier, so the point is moot. :doh: I should know that. I know selectables run higher, I'll check out ARB.
Blue XJ Posted January 24, 2010 Posted January 24, 2010 4wheelparts was offering 10% off on ARB's a few weeks ago when I bought mine from them. :cheers:
